Seasonality normalized / not normalized
Postby Djobydjoba » Sun Feb 05, 2023 4:28 am
1) That would be nice if the option to switch between normalized and not normalized seasonality could be more directly accessible, eg. by the context menu of seasonality Graph/Report or by the menu. Both calculation modes are useful on a daily basis when working on seasonality, so the ability to quick switch between the two. Would be even greater with a keyboard shortcut.
2) The several Online Help pages on seasonality are a bit unclear, because essentially written with the normalized seasonality in mind.
This is what can be read in the seasonality pages:
numbers less than 0 indicate the performance during this calendar period were below average, and numbers greater than 0 indicate above average performance.
but this is only accurate when the seasonality is normalized. For not normalized seasonality it would be:
numbers less than 0 indicate the average performance during this calendar period were negative, and numbers greater than 0 indicate positive average performance.
In the same way, the seasonality definition that is given is only valid for the normalized seasonality:
Seasonality measures the relative performance of calendar periods within a year. The measurement is typically calculated over multiple years. Seasonality shows which times of the year the item typically performs above/below average.
So the Online help should maybe be reworked to make a better distinction from the beginning between normalized and not normalized seasonality, and adapts definitions and explanations afterwards depending on the two calculation modes.
Postby Mark » Mon Feb 06, 2023 4:31 pm
Excellent points, thanks. We'll clean this up.
