Small bug (or not) when using "Customize"
Postby jtelne » Thu Sep 18, 2008 10:36 am
Hi!
I'm using Fund Manager Professional 9.2 .
When I click with the right button on Toolbar, and use the command "Customize" I check to remove the "Symbol" field.
It works but if I leave and restart Fund Manager the "Symbol" field appears again.
This only happens with this field, so I don't know if is designed this way or is it a bug (this happens on the "Portfolio Editor Columns To Display Dialog").
On another subject, I must say that I love Fund Manager and this is one of the best programs I worked with.
Keep up the good Work!
J. C.
jtelne
Postby Mark » Tue Sep 23, 2008 9:59 am
Hi J. C.,
Thanks for the bug report (and compliment on FM). I see this same problem too, and will get it fixed for the next release.
