Bug Report - Dates truncated when report copied to clipbrd
Postby ljbc01 » Wed Oct 19, 2016 10:52 pm
When a report includes a date in a column of the report the last two digits are dropped when using the copy-to-clipboard function.
Eg. 2016/10/12 is truncated to 2016/10/
I suspect this got missed in the conversion to 4-digit years in reports.
So far I have found two reports where this occurs:
- Investment transactions
- Open Lots
How to check this out:
1. set [Options | General Preferences | Display] to <windows Format> OR YYYY-M-D
(<windows format> lets you use yyyy/mm/dd format that I use rather than dashes)
2. run a report that includes a date in a column (like the two above)
3. then right-click on the report | copy text
4. then paste into notepad (or any text editor)
I am running FM Pro 2016.14.11.100
Thanks - Lloyd
ljbc01
Postby Mark » Thu Oct 20, 2016 8:25 am
Hi Lloyd,
Thanks for the clearly documented bug report. I see the same problem. We'll have this fixed for the next release.
Postby ljbc01 » Mon Nov 07, 2016 10:11 pm
Mark wrote:Hi Lloyd,
Thanks for the quick fix included in Version 2016.14.12 and released in 2016.14.13.
- Lloyd
ljbc01
