upgrade
Postby alpappy » Sat Feb 13, 2016 5:42 pm
HI mark
Thanks great software I only need the have customised reports IS the only way to upgrade from the base prog...If so how much is that
Can I just download and carry on or does the data need to converted
alan
alpappy
Postby Mark » Sun Feb 14, 2016 10:41 am
Hi alan,
You can upgrade from the Personal to Professional version for $260. You would need the Professional version if you'd like the user-defined fields in the Custom report feature. Upgrading is easy, you just install the new version and continue on. There is no data conversion necessary.
