Scrolling
Postby neri » Tue Aug 11, 2015 3:31 pm
Is it possible to have the security name and ticker locked and let the rest of the columns scroll?
It would be significantly easier to read.
Also, when will you update the column headings to 2 lines or at least allow for a smaller font? Most of the time, an entire column heading is not visible.
neri
Postby Mark » Tue Aug 11, 2015 4:07 pm
Hi neri,
Thanks for the feedback. You cannot lock the first 1 or 2 columns, nor is there a feature to have multiple line column headers. We're utilizing a standard list view control from Windows. To add those features would require writing a new custom list view control, which means significant development resources. Providing an option to customize the header's font (independent of the list view) is much easier, and we can consider this for a future update.
