Investment order
Postby finnsol » Fri Aug 05, 2016 2:13 pm
I'm afraid I am not able to describe what I'm looking for.
I do not want to change the given stack-order.
But if say stock no. 14 in the portfolio is displayed.
And I want to jump to stock no. 1 in the stack-order.
Then it used to be an easy way just to tap: ALT Investments -> Order -> Enter.
I'm sorry if I'm just confusing you.
Kind regards, Finn
finnsol
Postby Mark » Fri Aug 05, 2016 4:11 pm
Hi Finn,
How about using "Alt + I and then R", which select "Investments / Revert Order". That will put the stack back in the same order as when you initially opened the portfolio, and move the displayed investment to the top of that stack.
Postby finnsol » Fri Aug 05, 2016 11:45 pm
Hi Mark (are you still with me :roll: )
Maybe I know the reason for the confusion.
The shortcut sequence is: ALT I -> Enter -> Enter.
Twice Enter - without changing any order.
The stackorder is correct and I don't want to change it.
The purpose is just to jump to investment no. 1 when scrolling somewhere in the portfolio.
And to be sure Inv. no. 1 is displayed next time you open the portfolio.
It worked like a charm in earlier versions.
Kind regards, Finn
finnsol
Postby Mark » Sat Aug 06, 2016 7:19 am
Hi Finn,
Understood, but that won't work anymore, since we added support for multiple graph windows. There is now just one investment stack, and each graph moves positions in that stack. The Investment menu lists the order for that window. If you use the "Revert" menu shortcut that I mentioned, you will see that it puts things back to how they were when you opened your portfolio file. Give it a try, and see how it works.
Postby finnsol » Sat Aug 06, 2016 9:34 am
Hurrah! Thats it.
And the shortcut is shorter than before. Hat off! - and thank you.
Finn
finnsol
Previous
