LSE stocks
Postby realbg » Thu Jun 03, 2010 10:44 pm
Hello,
I have bought some stocks that are traded on LSE. The problem is at LSE the stock prices are quoted in Pences (Cents) rather than Pound (Dollars).
So, I bought 1,000 shares at 400p each = 4,000 pounds. Because 400 pence = 4 pound.
The price quote (no matter Bloomberg or Yahoo) will quote prices in pences not poundes.
So, If I mark the transaction as 1,000 shares at 4.00 Pound/share, then the P&L will be incorrect, because the Bloomberg quote will import 400P giving me 10000% gain.
The only way to mark the transaction for the P&L to be correct is to mark it as 10 shares at 400 Pound/share. Then, it will be streamlined with the quote, but this is not ideal.
In short, is there a function that automatically divide the price quote by 100 so that I can mark both quantity and price correctly?
Thank you.
Aileen
realbg
Postby Mark » Fri Jun 04, 2010 8:26 am
Hi Aileen,
There are 2 different solutions for this:
1) Use the "Yahoo - UK & Ireland" quote server, and make sure your symbol has the ".L" suffix. This will correctly retrieve in pounds.
2) If you want to use a different server, you can set a price retrieval multiplier of 0.01 under "Investment Properties... / Internet Retrieve".
If you only want to retrieve certain investments from Yahoo - UK/Ireland set this quote server for just those investments under "Investment Properties... / Internet Retrieve", and leave all the other ones set to use your default quote server.
