Lock Graph Windows
Postby gmow » Mon Oct 06, 2025 7:08 am
I have multiple graph windows open (e.g., pie charts and a share price chart). I use an editor window to select data.
The Issue: If I accidentally click a graph window (like a pie chart) that isn't the intended target (the share price chart), a subsequent selection in the editor updates the *wrong* graph. This happens because it's hard to tell which window is currently active.
My Requests:
1.Window Lock: Is there a way to **lock a graph window** (e.g., a pie chart) so it ignores data selections from the editor?
2.Undo Feature: Is there an **undo option** to revert the last unintended update to a graph window?
Please advise on solutions or workarounds.
gmow
Postby Mark » Mon Oct 06, 2025 10:16 am
Hi gmow,
Okay, thanks for the feedback. There is no lock feature like this, so I don't really have any workaround to suggest on this. The only "undo" feature in graphs is when you do a mouse zoom. You can hit the 'u' key on the keyboard to undo a mouse zoom. There is no undo option to revert the investment stack scroll position on a graph window.
Postby Djobydjoba » Mon Oct 06, 2025 10:24 am
Hi gmow,
Maybe a solution/workaround: you could activate the graph option "Prefer to Open Graphs in New Window" so your current open graph windows won't be altered.
Postby gmow » Mon Oct 06, 2025 11:50 am
Djobydjoba wrote:Hi gmow,
Thanks, I'll give it a try
gmow
Postby gmow » Tue Oct 07, 2025 10:42 am
When using this option anyway to have graph pre-configured
Share Price + MA Overlay
gmow
Postby Djobydjoba » Tue Oct 07, 2025 11:08 am
No... I think FM uses the graph type of the last active graph window or, if no graph window is currently opened, it opens with the Share Price graph type.
Postby AssetHound » Thu Nov 13, 2025 11:07 am
Two thoughts. It would actually be nice to be able to lock a graph and settings. I have one that shows up on the bottom of my screen -- editor on top -- that I use to track portfolio performance versus indexes. I can't tell you how many times I've hit something and the graph either disappeared or changed settings and overlay investments. Once I had to go to my backup copy and start over.
This one chart is extremely helpful; otherwise, I use a dedicated charting package but is separate software.
Second, to get the chart of my indexes on the same chart as my portfolio, I created a new portfolio called "Indexes." I had to put in 1 share but since it is separate from my real portfolios, the value doesn't get added to summary reports of portfolios. It's entirely possible that I missed something, but I can't seem to add indexes without creating a portfolio for them. Is that correct? Thanks.
AssetHound
Postby Mark » Fri Nov 14, 2025 2:11 am
Hi AssetHound,
Thanks for the feedback.
All open investments must belong in some sub-portfolio, so it is very normal to create a new sub-portfolio for your indices. It is not necessary to own shares, but it really doesn't hurt either since they are in a separate sub-portfolio, outside your accounts.
