Customizing
Postby paulstonge » Thu Sep 04, 2008 9:57 am
I am evaluating Fund Mgr and would like to customize to a much greater extent than the custom report allows. Are there any work arounds for this that I might be missing?
paulstonge
Postby Mark » Thu Sep 04, 2008 10:31 am
Hi paulstonge,
What specifically are you looking to customize? Do you mean some other calculations not available in Fund Manager, or are you talking about the formatting, colors, fonts?
Postby paulstonge » Thu Sep 04, 2008 10:40 am
One report that I like keeps track of the portfolio by qrtr, i.e:
Date Added/Withdrawn Market Value Index
6/30/06 140,000.00 138,542.10 .990
9/30/06 143,875.08 1.028
12/31/06 220,000.00 382,357.53 1.102
3/31/07 8,000.00 397,345.44 1.122
6/30/07 9,000.00 432,559.34 1.196
9/30/07 4,000.00 453,470.71 1.242
12/31/07 449,509.02 1.231
3/31/08 421,659.59 1.155
6/30/08 4,000.00 420,982.17 1.142
9/ 3/08 -25,000.00 377,103.56 1.090
paulstonge
Postby Mark » Thu Sep 04, 2008 11:14 am
Hi paulstonge,
There is no report formatted in this way, and no option to do exactly this. I can think of a couple of options:
1) Use a report with multiple date ranges. You can have up to 6 in a given report. You can get the "Added/Withdrawn" and "Market Value" fields in a report. I'm not sure what "Index" would translate to in Fund Manager. You would have essentially the same report, but it would be transposed to horizontal instead of vertical.
2) Create a report with this information, and copy/paste the data to Excel, and make your report the way you're used to. See:
http://www.fundmanagersoftware.com/faq_export_excel.php
