by Mark » Thu May 15, 2008 3:12 pm
Hi jerryo,
In any version you can memorize any layout you want. Set up a custom report, and then choose "Edit / Memorize..." to assign that report a new name. It will then be listed under the "Reports" top level menu, so you can re-create it again. You can do things like pick which columns to display, and set their order in the report.
In the Advisor version you can customize the column labels. Only the Advisor version has this feature. You must stick with the default labels in the Pro/Personal versions. In the Advisor version you can rename any column to anything you want, and it is memorized for all future reports. Just choose "Options / Column Labels...".
If you want to try it out, you can install the Advisor version, and run it as a trial. If you decide you want to stick with the Professional version, just re-install that when you are done. All the data files are compatible and interchangeable between the 3 versions.
