Ing Institutional Name Change
Postby 12garyv » Fri Sep 12, 2014 1:43 pm
Since Ing changed its name to Voya, FM has been unable to connect to my accounts. Are there new Retrieve settings that I may need?
Thanks for your help.
Gary.
12garyv
Postby Mark » Fri Sep 12, 2014 4:10 pm
Hi Gary,
Thanks for pointing this out. We've just released an update to address this. See:
viewtopic.php?f=2&t=3192
Postby 12garyv » Sat Oct 11, 2014 6:24 pm
I downloaded the update but I am still not able to connect. I am using the same username and password that works on the nestle.voyaplans.com website. I tried setting up a new sub-portfolio to see if that would work but no luck.
Appreciate any further help you can provide.
Kind regards,
Gary.
12garyv
Postby Mark » Sat Oct 11, 2014 6:37 pm
Hi Gary,
We've had reports of success from other users, but they had to use "username@ing" instead of "username@voya" to login. If you try that, does it work? Also, I assume you've selected the new "Voya Institutional Plan Services" interface, and not the "ING Financial Partners" interface?
Postby 12garyv » Wed Oct 15, 2014 7:08 pm
Thanks for your reply. I was still using Ing Financial Partners; Voya solved the problem.
Gary.
12garyv
