N/A in Footer Totals after upgrade
Postby kariim_j » Wed Jul 02, 2014 1:43 pm
Hello,
I just upgraded to Professional from Personal version 10.9. When asked to convert DAT files to new format I chose Yes. Now all my legacy reports are showing N/A in Totals in footer.
It used to work fine under previous version. Your guidance is very much appreciated.
kariim_j
Postby Mark » Wed Jul 02, 2014 1:48 pm
Hello kariim_j,
Please turn on "View / Exchange Rate Adjusted", and you should see your totals. For details on this, please read this FAQ:
http://www.fundmanagersoftware.com/faq_ ... encies.php
This is a change in behavior, starting with Fund Manager 2014.
Postby kariim_j » Wed Jul 02, 2014 9:33 pm
Thanks Mark. I have under Footer Gain and Gain% which are now fixed. I also have TWR and ROI returns which are still showing N/A!
kariim_j
Postby Mark » Wed Jul 02, 2014 9:50 pm
Hi kariim_j,
Select "Help / Help on Report..." and you should see an explanation of any "N/A" terms.
Users browsing this forum: Google [Bot] and 10 guests
