when trying to access "webnews" or "post a question on Fund manager message board" i get the following error: Other shellexecute error: 5 -. Might you have a solution for this ? Am running 11.4.
steve
Message board and Webnews Error
Hi Steve,
With these commands Fund Manager is using your Windows shell to open a website URL. The error message you're getting indicates there is some permission problem. Somehow your shell is not configured correctly to allow opening of URLs. To test this, go to "Start / Run..." and where it says "Open:" type in a URL, like: http://www.fundmanagersoftware.com and then press OK. If your shell is configured properly it should open this URL in your default web browser.
Hi Steve,
What version of Windows are you running? If you're running Windows 7, check under "Control Panel / Default Programs / Set Associations". You should have a long list of associated "Extensions" and "Protocols". Under the "Protocols" section, you should have a protocol for "HTTP" and it should be set to a valid web browser that you have installed on your system.
Who is onlineUsers browsing this forum: No registered users and 8 guests |
