This dialog is available from the File / Import / Positions / Ameritrade... menu command.
Position data can be imported from Ameritrade p*.dat files, available for download to Ameritrade Advisors. During the position import Fund Manager will look for a corresponding s*.dat file for the p*.dat file. The s*.dat file contains closing pricing and additional security information, such as the security names and types. If the s*.dat file is found, this additional information will also be imported.
DAT File to Import |
Select which p*.dat file to import. |
Accounts to Import from DAT File |
Choose whether to import all accounts in the selected file, or only a particular account. Use the "Scan DAT" button to fill in the list of available accounts in the importing file. |
Import Options |
Choose options for creating the new investments. Choose whether to import all positions into a new sub-portfolio:
Ameritrade's position files offer both "traded" and "settled" share balances. Choose which share balance to import. |
Press the "Next" button after filling in all of the above fields. The importing file will be read in, and you will be taken to the Preview Importing Positions page to see what transactions will be imported.
Important Note on Cost Basis:
When importing positions there is no cost basis data available. Therefore, all positions will be created with a cost basis of zero. To adjust the cost basis, use the Data Register and edit the initial purchase price and value.
Importing Ameritrade Transactions
