Stock Option Quotes
Postby trader1 » Tue Jan 26, 2010 9:57 am
Cannot find any stock option symbol information that will download quotes into Fund Manager. The symbols I use will pull up correct option quotes on the yahoo web site, but will not download into Fund Manager. Ex: QQQQ Feb 14 Calls have symbol X.QQQBR from the CBOE. Yahoo uses QQQBR.X for their symbol, but it will not download into Fund Manager. Any help would be appreciated. Thanks
trader1
Postby Mark » Tue Jan 26, 2010 11:09 am
Hi trader1,
Yahoo changed their symbols for options, and also no longer provides option pricing in the "Download" format. If you look up that quote on Yahoo, you'll see the new symbol is: QQQ100220C00044000. Also, unlike stocks/mutual funds, there is no "Download Data" link, which is where Fund Manager is currently getting the quotes on Yahoo.
It is possible they may add the download format back in once they get things straightened out. However, we are planning on adding a new server "Yahoo (Options)" that will get the option quotes directly from the HTML instead of using the "Download" link.
We've just now updated the online status for this server, and you can check back periodically by selecting "Help / FM on the Web / Check for Updates...". When the new quote module is available you'll be able to download it through this command.
Postby Mark » Wed Jan 27, 2010 4:37 pm
Hi trader1,
A new quote module is now available that offers this new "Yahoo (Options)" server. For more details on this server, see the announcement.
Postby Homer » Wed Jan 27, 2010 8:59 pm
Did the updates to the modules and picked the Yahoo(options) server and changed the symbol, but still can't see to get the prices to update yet. Please keep and eye on this.
Homer
Homer
Postby Mark » Wed Jan 27, 2010 9:18 pm
Hi Homer,
What is a sample ticker symbol that you're trying to update?
Postby Homer » Wed Jan 27, 2010 9:36 pm
Here are a couple
XUX110122C00016000
VBA110122P00007500
I am probably going to have to update the CUSIP also to match the new symbols at my broker, huh.
John
Homer
Postby Mark » Wed Jan 27, 2010 10:25 pm
Hi John,
Thank you. I see the same problem when using these symbols. It looks like we will need to publish another quote module update to fix this.
I'm not sure if the CUSIP will change on options or not...
Postby Homer » Wed Jan 27, 2010 10:57 pm
Thanks for checking this out this evening.
Homer
Homer
Postby Mark » Thu Jan 28, 2010 8:25 am
Quote module 412 is now available, and fixes this problem. Thanks for pointing it out.
Postby Homer » Thu Jan 28, 2010 7:16 pm
[color=darkblue][/colojavascript:emoticon(':D')r] :D
Thanks Mark. If you use the Yahoo Options server it works again.
Homer
Homer
