Import
Postby JFM » Sun Jan 26, 2020 3:09 pm
Trying to use the file/import/transaction/generic function. See attached. What am I doing wrong?
Note to FM.xlsx
A sample of the problem
(11 KiB) Downloaded 286 times
JFM
Postby Mark » Mon Jan 27, 2020 9:41 am
Hi JFM,
Can you attach the .CSV file you're importing, and also tell me the format string you're using?
Postby JFM » Mon Jan 27, 2020 10:20 am
The format string I used is
SYMB,MM/DD/YY,TRAN.ANUM,BNUM,CNUM
Attached is the .csv file.
Thanks for the help
Test of ALGN.csv
(106 Bytes) Downloaded 295 times
JFM
Postby JFM » Tue Jan 28, 2020 9:03 am
Found the problem - looking closely at the header string, I had a "." and not a ","! Duuuuugh! Thanks. It works fine now.
JFM
Postby Mark » Tue Jan 28, 2020 9:23 am
Hi JFM,
Great, glad you solved it.
