generic price import
Postby flight » Sat Jan 07, 2017 7:24 am
Is this format string acceptable for importing generic (.txt file) prices?
09/22/09 3.50
09/23/09 3.25
09/24/09 3.55
09/25/09 3.05
09/28/09 4.25
09/29/09 4.25
09/30/09 4.70
10/01/09 4.36
10/02/09 4.14
10/05/09 4.09
10/06/09 3.56
10/07/09 3.42
10/08/09 3.50
10/09/09 3.10
10/12/09 3.25
10/13/09 3.20
10/14/09 3.16
10/15/09 3.00
10/16/09 2.88
10/19/09 2.99
10/20/09 3.30
10/21/09 3.27
10/22/09 3.96
10/23/09 3.80
10/26/09 3.84
10/27/09 4.03
10/28/09 3.84
10/29/09 3.40
10/30/09 3.29
11/02/09 3.27
11/03/09 3.50
11/04/09 3.44
11/05/09 3.16
11/06/09 3.56
11/09/09 3.40
11/10/09 3.85
11/11/09 3.84
11/12/09 3.95
11/13/09 3.38
11/16/09 3.37
11/17/09 3.27
11/18/09 3.44
11/19/09 3.39
11/20/09 3.14
11/23/09 3.20
11/24/09 3.25
11/25/09 3.48
11/27/09 3.10
11/30/09 3.13
12/01/09 3.16
12/02/09 3.17
12/03/09 3.06
12/04/09 3.10
12/07/09 3.00
12/08/09 3.05
12/09/09 3.15
12/10/09 2.88
12/11/09 2.93
12/14/09 3.15
12/15/09 3.14
12/16/09 3.10
12/17/09 2.79
12/18/09 2.99
12/21/09 2.78
12/22/09 2.74
12/23/09 2.59
12/24/09 2.70
12/28/09 2.84
12/29/09 2.93
12/30/09 2.92
12/31/09 2.80
flight
Postby Mark » Sat Jan 07, 2017 8:02 am
Hi flight,
Yes. You would use the format string:
MM/DD/YY NAV
and "Specify" the symbol.
Postby flight » Sat Jan 07, 2017 10:35 am
I thought so, but got the message "the specified input format did not match any lines in the imported file".
I used the one ending in PRN format
flight
Postby Mark » Sat Jan 07, 2017 3:09 pm
Hi flight,
I just test imported it using these settings, and it worked correctly. Did you look at your price file with a text editor? If you're viewing it in Excel there may be other formatting characters you're not seeing. I've attached the file I imported so you can try it too. The format string is:
MM/DD/YY NAV
and you must "Specify" the symbol, but not the date.
prices.txt
price file
(1.04 KiB) Downloaded 299 times
Postby flight » Sun Jan 08, 2017 6:54 am
that txt file didn't work either. i attached a screen shot.
flight
Postby Mark » Sun Jan 08, 2017 11:54 am
Hi flight,
You aren't entering the format string. In the edit box that says "Input Format", you can type directly in there. You don't have to just press the down arrow and choose one of the recent ones. Type directly in that box, and enter:
MM/DD/YY NAV
which is the format of your data and that file.
Postby flight » Sun Jan 08, 2017 12:09 pm
That worked. Thanks Mark!
flight
Postby flight » Fri Feb 03, 2017 6:44 pm
Is this a valid import for transactions:
SYMB,TRAN,MM/DD/YY,ANUM,BNUM,CNUM
GSIP BUY 07/30/12 15.95 62.6959 0
VSIP BUY 07/30/12 15.40 64.9351 0
GSIP BUY 09/27/12 16.81 34.652 0
VSIP BUY 09/27/12 16.10 36.1801 0
GSIP BUY 10/11/12 16.53 30.248 0
VSIP BUY 10/11/12 16.09 31.0752 0
GSIP BUY 10/12/12 16.53 30.248 0
VSIP BUY 10/12/12 15.99 31.2695 0
VSIP BUY 10/24/12 15.90 31.4465 0
GSIP BUY 10/24/12 16.19 30.8833 0
GSIP BUY 10/24/12 16.19 13.8975 0
VSIP BUY 10/24/12 15.90 14.1509 0
GSIP BUY 12/11/12 16.56 60.3865 0
VSIP BUY 12/11/12 16.14 61.9579 0
flight
Postby Mark » Fri Feb 03, 2017 8:10 pm
Hi flight,
Yes, but you need to enter the format string that matches the format of your data. Since your data is space delimited, use a space in your format string, instead of a comma. It would be:
SYMB TRAN MM/DD/YY ANUM BNUM CNUM
