Command line alerts
Postby pauyo » Tue Sep 13, 2016 4:41 am
I am using automatic update via Task Scheduler and command line and it is working fine using the /I and /Q switches. I would love if you can add a switch for triggering and sending alerts when a price updated is performed would be much appreciated.
/Paul
pauyo
Postby Mark » Tue Sep 13, 2016 9:58 am
Hi Paul,
This already happens automatically. If you have any price alert set and it gets triggered when you do an automatic update, that alert will activate, and you will be notified, however you've specified. Make sure you've chosen an email notification method, instead of just the popup window. See "Options / Alert Settings...".
Postby pauyo » Thu Sep 15, 2016 7:57 am
You are right Mark, I have verified it working. Thanks!
/Paul
pauyo
