Yahoo Servers Down - Status Update
Postby Mark » Wed Jul 13, 2016 9:56 pm
Yahoo Finance changed their site on July 12, and the following quote servers are currently not working:
Yahoo (Historical)
Yahoo (Options)
Yahoo (Realtime)
We are working on an update to restore them ASAP. You can check the status under "Help / FM on the Web / Check for Updates...".
Postby Mark » Thu Jul 14, 2016 6:04 pm
Quote module 497 is now available that fixes all the Yahoo servers, and adds support for additional servers. The Yahoo (Historical) server requires Fund Manager 2016.14.8 or later, which is available now on the download page. For information on all the available quote servers, please see:
https://www.fundmanagersoftware.com/intrtv.html
Postby flight » Thu Jul 14, 2016 6:58 pm
I think this was possibly address in another post, but can you please advise the FM 14 users on what they should do? I saw your comment about it working with FM 16, but not sure this helps those who didn't have plans on upgrading at the moment. thanks
flight
Postby Mark » Thu Jul 14, 2016 7:02 pm
Hi flight,
You will have access to all the quote servers except Yahoo (Historical). You can still use Yahoo (Adjusted Historical) or either of the Google historical quote servers.
Currently we've reverted to 496 for the FM 2014 version, as there were issues with the 497 release and FM 2014.
Postby flight » Thu Jul 14, 2016 7:05 pm
Pardon if I missed it, but are there instructions on how to revert to the prior quote server?
Separately, I believe the indicies sub-portfolios that I created are now empty? does that make any sense?
flight
Postby Mark » Thu Jul 14, 2016 7:07 pm
To revert, delete your "inteng13x.dll" file, and do another "Help / FM on the Web / Check for Updates...".
I don't think the quote module should have anything to do with investments in a sub-portfolio. If you can't find them, or re-open the investments, maybe you need to restore from a backup.
Postby flight » Thu Jul 14, 2016 7:34 pm
It says it is already open, but when I look at the main window, it is blank/empty.
flight
Postby Mark » Thu Jul 14, 2016 7:44 pm
Maybe it is open in a different sub-portfolio, or it is hidden? Try turning on "View / Hidden Investments/Portfolios". You can also run a Portfolio Value report, and filter by symbol. Put your cursor over the investment, and in the status bar it will show you the sub-portfolio hierarchy where it is located.
Postby robert1 » Thu Jul 14, 2016 8:10 pm
I am running the 2014 Advisor Version of Fund Manager.
Am I right in my understanding that in order to continue using the Yahoo (Adjusted Historical) server I have to upgrade to Fund Manager 2016?
Robert
robert1
Postby Mark » Thu Jul 14, 2016 8:16 pm
Hi Robert,
No, you don't have to upgrade. The "Yahoo (Adjusted Historical)" server is still working in FM 2014. The "Yahoo (Historical)" server will continue working in FM 2014, except for the retrieval of dividends/splits that this server is capable of. To get that feature you would need to upgrade to FM 2016. This update will be available later tonight with quote module 498.
Postby Mark » Thu Jul 14, 2016 9:16 pm
I apologize for the problems with the 497 quote module. It was not backwards compatible. We've fixed the problem, and released quote module 498. You can get it with "Help / FM on the Web / Check for Updates...". It is available for both FM 2014 and FM 2016. The Yahoo (Historical) quote server will retrieve prices in both versions. If you are using a Professional or Advisor version and wish to use this server to retrieve dividends/splits you will need to be using FM 2016.14.9 or later. A description of all the changes in the quote module is available here:
https://www.fundmanagersoftware.com/int ... sions.html
Postby flight » Sun Jul 24, 2016 6:55 am
The investment was indeed hidden. And, there were no transactions recorded. Following discovering that, I have unchecked the hidden box and recorded a transaction as described here: https://www.fundmanagersoftware.com/faq ... arison.php. Additionally, I have confirmed the "retrieve price" is checked off for internet retrieve and default server selected.
However, FM says "could not update any investments" when I try updating historical prices for the S&P Total Return, ticker "SPTR:IND". Am I using the correct server?
The S&P 500 Price Return Index "^GSPC" is working fine. that is the good news.
Below is the log....
Retrieve Starting
Quote Module Version = 501
Requested Historical Retrieve Dates: 7/1/2016 - 7/24/2016
Requesting: "SPTR:IND"
WARNING: Server used but did not update any prices: (YAHOO-HISTORICAL)
flight
Postby Mark » Sun Jul 24, 2016 8:41 am
Hi flight,
The symbol you're using looks like it is from the Bloomberg server. When using Yahoo you would want to change it to the symbol Yahoo uses for the S&P 500 Total Return, which is: ^SP500TR.
Postby progers1947 » Mon Aug 01, 2016 2:55 am
Hi Mark
I was having problems retrieving prices from Yahoo Historical, they were down this morning until about 5 minutes ago when they suddenly started working again.
Peter
progers1947
