Bug in quote module 494
Postby mogul456 » Mon Apr 11, 2016 1:18 pm
Hi Mark, I think you have a bug in the recent quote module because I get a message that the yahoo site has a bad security certificate. FM then says to reinstall the program. I have not upgraded to the current version yet so I reinstall and it uses a very old quote module. The prices seem to update but FM prompts to update to the 494 module. If I update I get the same problem as before. I think you may have to take down 494 until the backward compatibility issue is resolved. thanks|fc
mogul456
Postby mogul456 » Mon Apr 11, 2016 1:31 pm
Mark: I found your update for 2014 to fix the problem. thanks|fc
mogul456
