Date format not used consistently
Postby mclouter » Tue Feb 02, 2016 5:16 pm
I prefer using the yyyy-mm-dd format for dates but have noted that this choice does not propagate through to the transaction dialogues, e.g. the Distribution Transaction. Is this intentional or is there an option I am missing? Thanks.
mclouter
Postby Mark » Tue Feb 02, 2016 8:51 pm
Hi mclouter,
The date controls in dialog boxes use the date format specified in your regional settings in Windows. The Fund Manager date formats are used everywhere else. In Windows, if you search for "Region and language", you can set the date, time, number format used in Windows, and this will also control these date controls.
Postby mclouter » Tue Feb 02, 2016 9:33 pm
Great - thanks.
mclouter
