by chask89 » Mon Mar 21, 2011 6:53 am
I have been using FM Pro 10.7 with no problems and can retrieve all transactions for 10 accounts. When I upgrade to 10.9 I get a message that states there are no accounts for that user name. Any suggestions?
I am using same user name and password in both versions.
chask89
by Mark » Mon Mar 21, 2011 8:16 am
Hi chask89,
There were several changes in this server a while ago. Please make sure you've downloaded the latest transaction module by using "Help / FM on the Web / Check for Updates...". Try it again with the latest module, and let me know if you still have troubles.
by chask89 » Mon Mar 21, 2011 8:44 am
Mark wrote:Hi chask89,
I have tried the updated transaction modules, that is when the problem starts. Only module that seems to work is 137
chask89
by Mark » Mon Mar 21, 2011 8:49 am
Can you still retrieve okay with module 137? If so, can you send me the log files using 137, and then the log files using 422?
After a transaction retrieve there will be 3 log files: "ofxpost.txt", "ofxretr.txt", "xmldump.txt". The log files will be located here:
Windows XP and earlier:
C:\Documents and Settings\<username>\Application Data\Fund Manager
Windows Vista and 7:
by chask89 » Mon Mar 21, 2011 9:54 am
Mark wrote:Can you still retrieve okay with module 137? If so, can you send me the log files using 137, and then the log files using 422?
After a transaction retrieve there will be 3 log files: "ofxpost.txt", "ofxretr.txt", "xmldump.txt". The log files will be located here: Windows XP and earlier: C:\Documents and Settings\<username>\Application Data\Fund Manager Windows Vista and 7: C:\Users\<username>\AppData\Roaming\Fund Manager
Have searched my computer, do not find those files or those directories
chask89
by Mark » Mon Mar 21, 2011 10:20 am
The "Application Data" or "AppData" folders are hidden, so you will need to turn on the display of hidden files/folders. If it would be easier, you can just give me a call, and we can work on this together over the phone. Click on "Contact Us" in the upper/right corner of our website, and you'll see our contact info.
by chask89 » Mon Mar 21, 2011 1:21 pm
I have no problems with Module 137.
The files you listed are not found anywhere on my computer.
chask89
by Mark » Mon Mar 21, 2011 1:39 pm
Just to document the results of our phone support... Once you see the message that Morgan Stanley reports no accounts associated with your login, press OK, and then "Yes" when Fund Manager asks if you want to retrieve anyway.
