New options Tickers
Postby 4Profits » Fri Feb 12, 2010 3:56 pm
Mark I am not able to retrieve anu options with the new ticker symbols. They worked for a few days but no longer. I am using the Yahoo server and have even gone to yahoo and copied the option ticker into the Fundmanager symbol. I finally made up a sample project with about five options in it and tried to do a price update and nothing was retrieved. Any ideas.
For example Kingross Gold March $17 Call symbol from Yahoo is
KGC100320C00017 when I go to yahoo finance and enter that I get the price but fundmanager will not update it.
Jim
4Profits
Postby Mark » Fri Feb 12, 2010 5:15 pm
Hi Jim,
A little while ago the regular "Yahoo" quote server stopped providing option quotes. We added a new server called "Yahoo (Options)". If you set your option investments to use this quote server they should retrieve okay. You can make this assignment under "Investment Properties... / Internet Retrieve". Also, make sure you have the latest quote module (414) by doing a "Help / FM on the Web / Check for Updates...".
Postby 4Profits » Sat Feb 13, 2010 10:14 am
Thanks, That fixed it
4Profits
Postby Robert A » Tue Mar 02, 2010 11:07 am
Mark, I'm using FM 9.7 with module 414. I don't see a Yahoo(options) server, just Yahoo, Yahoo adjusted, Yahoo historical.
I need a way to update options pricing.
Robert A
Postby Mark » Wed Mar 03, 2010 7:10 am
Hi Robert A,
The new server is only available in the 10.x versions. We maintain existing servers for the last 2 major versions (9.x and 10.x). Any new servers are only available in the most recent versions (10.x).
