REPORTS-CUSTOM
Postby robert1 » Sun Nov 15, 2009 5:44 pm
I attempted to print out my custom report after downloading the maintenance update, but it showed the fund symbol in all columns. Previously, I was able to customize the columns to show the year-to-date, 6 week 1 month percentage returns in addition to the 3, 6 month and 1, 3 ,and 5 year returns that had been standards. Am I doing something wrong? THANKS for your help!!
robert1
Postby Mark » Mon Nov 16, 2009 8:29 am
Hi robert1,
Does your printout look okay on the screen, or only on the printout? How about print preview? Maybe you can email me a screen shot of the problem report?
Postby robert1 » Mon Nov 16, 2009 10:38 am
It didn't look Ok on the screen. All the columns had the fund symbol in it, so I didn't print it out. I'll be happy to email you a screen shot. Can you tell me the steps to do that please?
robert1
Postby Mark » Mon Nov 16, 2009 11:07 am
Hi robert1,
I've just sent you an email with instructions. You can reply to that with your image attached.
Postby robert1 » Wed Nov 18, 2009 8:18 am
I attempted to check my report settings as you suggested, but couldn't get it to revert back to the previous format. It's certainly possible that I wasn't sure of the exact steps necessary to do that however. Any suggestions?
robert1
Postby Mark » Wed Nov 18, 2009 9:45 am
Hi robert1,
While looking at your report, choose "Edit / Report Settings...". Check your date range options here. If you only want a single date range, change this down to 1. Next, press "Custom Settings..." and make sure you have the fields you want. It looks like you only have "Symbol" included in your report now.
