I've been using the custom report to look at performance returns. In the printout the symbols print in the data area. Any idea what's causing that?
Symbols printing in the data fields
Hi robert1,
If you select the report you want to print, so it is in the foreground, and then choose "Window / Auto-size Columns" before printing, does that fix the problem?
I believe I followed the instructions properly, but the symbols still printed in the data columns. Sometime back I asked for help with the custom report print format I wanted and you said I needed to copy & paste it into notepad first and them format. Would that make a difference?
