save portfolio as csv
Postby alpappy » Fri May 03, 2024 2:26 pm
HI Mark
Is it posible to save my portfolio as csv to import into a spreadsheet How can I do that
thanks
alan
alpappy
Postby alpappy » Fri May 03, 2024 2:30 pm
when I try export it says format illegal? Alan
alpappy
Postby Mark » Fri May 03, 2024 2:57 pm
Hi alpappy,
What about your portfolio exactly are you trying to export? All the transactions? The current holdings? Any report can be saved to a CSV file using "File / Export to CSV..." from within that report window. If you want all the transactions exported to a CSV file you can either export an Investment Transactions report, or customize it more with "File / Export / Transactions / Generic..." and where it asks for an "Export Format" use something like this:
SYMB,MM/DD/YY,TRAN,ANUM,BNUM,CNUM
Press "Help" in that dialog for more detailed instructions, but it might be simpler to just export a report if that meets your needs.
Postby alpappy » Fri May 03, 2024 3:05 pm
HI My accountant wants spread sheet format of the transaction for financial year buy sell dividends tax paid and buy commisions Will that format do all of that thanks alan
alpappy
Postby Mark » Fri May 03, 2024 3:09 pm
Yes, you can create an Investment Transaction report for the year, and export it to CSV with "File / Export to CSV...".
Postby alpappy » Fri May 03, 2024 8:29 pm
Thanks Mark using the transaction report worked perfectly Tax done in no time
Kind regards
alan
alpappy
