custom properties (Unrealized %Gain?)
Postby JeanneMarie » Wed Jun 29, 2022 4:20 pm
In my Portfolio Editor, I've got Basis, Unrealized Gain, and Unrealized %Gain.
In a report, I can get the first two but I cannot find the %Gain in the Custom Settings dialog.
This seems odd. And there are other instances where the same field has a different name in a different corner of the program. So I figured I'd ask. Should I be able to find this among Custom Settings?
JeanneMarie
Postby Mark » Wed Jun 29, 2022 4:37 pm
Hi JeanneMarie,
Actually, that percentage isn't available as a built-in field for the Custom report, but if you're using the Pro or Advisor version you can define a field with the equation:
100.0 * Taxunrlzgain_Assigned / Taxbasis_Assigned
to include it.
Postby JeanneMarie » Thu Jun 30, 2022 7:13 am
Thanks, Mark. Now I can stop wasting time searching.
No, I don't foresee moving up to the higher level versions. But I'm used to dragging *.csv files out to Excel to add some little computation or to slice and dice the data in a way that is not available as it stands. No prob.
Cheers!
JeanneMarie
