User-Defined Fields
Postby fiscalis » Mon May 16, 2011 2:58 pm
Hi Mark - in v 11.x, is there a way with the new user defined fields to have FM selectively pull particular investments into a report based upon specific asset types, investment goals, or types?
THANKS!
fiscalis
Postby Mark » Mon May 16, 2011 3:44 pm
Hi fiscalis,
User defined fields cannot help you do this, but report settings may be able to accomplish what you want. You can either sub-total by these items, or filter by them. For example, in a Portfolio Performance report, if you choose to subtotal by Asset Type and list by Investment, all investments of the same asset type will be grouped together, and then a sum for that asset type will be shown.
Alternatively, if you click on "Filter..." you can choose to filter by a variety of things, like Asset Type, so you can have a report that only shows a specified asset type.
