Column Widths
Postby Ron Myers » Fri Apr 15, 2011 6:07 pm
I ungraded to version 11.0, now my memorized reports are too wide to print (now columns are wider) and I have to adjust the column width every time before I print. Why does this happen?
If I delete the report and create a new report will this fix the problem?
Ron Myers
Postby Mark » Fri Apr 15, 2011 6:14 pm
Hi Ron,
By default in v11 column widths are sized to their content whenever the report is created or the report data/settings change. If you do not want it to auto-size automatically, you can turn this feature off under "Options / Report Preferences... / General / Auto-Size Columns When Report Data Changes".
After it does auto-size you can still manually re-size the columns by clicking/dragging the header. If you do turn off the auto-size feature, you can manually initiate an auto-size whenever you want using "Window / Auto-Size Columns".
This auto-size feature is new to v11. It sounds like you may have previously had slightly narrower columns (which means data was being truncated as it was displayed/printed), allowing you to print on a single page.
