REcording transaction in different currencies
Postby mkappa74 » Fri Feb 17, 2012 7:27 am
I'm currently using FM recording transaction related to $ investment while my default currencies is €.
I always got the problem with commission: even if I buy a $ investment, I pay commission in €.
FM translate commission from € to $ as it does with investment.
The only solution is to convert commission to $ ... or not?
thanks.
mkappa74
Postby Mark » Fri Feb 17, 2012 8:44 am
Hi mkappa74,
If your investment is being traded in $, then all prices/transactions for that investment must be recorded in $. I think the best solution is the one you mentioned, where you convert the € commission into $ and record it that way as part of the transaction.
Copyright © 1993-2013 Beiley Software, Inc. All rights reserved.
